I’m working on adding the various bits I have to GWizard. Adding my initial tool there was a nice picture asking me for various dimensions of the tool. Adding the second tool, it’s just a form with fields. Is there any way to get the first interface back, I can’t seem to find it.
When I am in my Tool Crib, and I tap on “New Tool”, and then tap on the dropdown beside “Type” it brings up that nice interface.
I have Estlcam telling me it takes 05:29 minutes. Since it’s a bit off with carves it might be closer to 10 minutes. E12 file in the attachment. I used a 10mm 60° V-Endmill for the calculation.
Sean.zip (1.3 MB)
Something like this?
This one: Sorotec Online-Shop - VHM-Gravierfräser
Used a 60 degree bit. Estlcam claimed roughly 10 minutes if I left the depth to auto. Gave it a shot, and got this in 30 minutes. Yes, Estlcam was way off.
It looks like I’ll need to change bits a few times. The small lettering appears to be too fine for the 60 degree bit. And the auto depth for the padre is too deep, killing quite a bit of the detail.
But seems like a good first pass.
Burning is always an indication that either your feed rate is too slow, or your RPMs are too fast or both. Particularly challenging with V bits. I would try nudging the RPMs down a little, and nudging the feed right up a little and see what kind of result you get.
Looking good! You’re off to a great start!
Another question. Between each individual cut, the toolhead raised quite a bit, like 30-50mm above the surface. Is that normal?
Depends on your clearance plane setting in EstlCAM. What is yours set for?
Odd, don’t recall setting that, but it’s set to 50.8mm.
Probably a default setting for that end mill.
Estlcam handles it in a global setting not tool based. Unless this is a version 12 feature.
It’s the global that I found set to that value.
