Just setup Mealie for storing recipes here at the house. I’m tired of scrolling through 10 blog pages to get to a recipe. Mealie’s coolest function is the ability to easily import a recipe from a link to the blogpost.
Why is this a big deal? I actually took the time to set it up like I would an environment at work.
I set up a coreOS vm in vSphere. There I run the mealie container. I also have a caddy container running to handle SSL encryption. The Let’s Encrypt validation is done through DNS based validation.
I’m using a Jenkins pipeline running in another VM to build the caddy container and it’s stored in a local docker repo running in my environment as well.
docker-compose starts up the stack on the vm.
A nightly cron job runs that backs up the mealie database to a .tar.gz file on my nfsserver that then gets backed up to S3 glacier.
The only thing I didn’t do is set up an ansible script to create the backup.sh, backup.service, and backup.timer files.
All the code/files are stored in github… cause where else would I put them.
No sure why I did all this. I just kept saying, “Well if I did that, I might as well do this”… until it was done.
Most of the time when I set something up, I get to MVP and just stop. Too busy using it at that point to keep building/configuring. Even my MP3DPv4 has things I still need to finish on it.
Anyone else ever feel like they went slightly overboard on a project at home just for the sake of “might as well” ?
