That’s like letting another man cook on your grill
I’d suggest you go go through the steps of making your own gcode to start getting your bearings with all this stuff. I’m sure we’d all be happy to help you through that process if you have specific questions. Re the v1 logo you can get svgs here: Logos | V1 Engineering Inc
Why not try loading one these into estlcam?
Yeah, that would be fun. Sort of like the crown, but for cutting?
@vicious1, You had a thing where you were just cutting out the logo (no words) in various materials. Do you think something like that could be the “crown” of milling? Make a v1 coaster from 1/4" material, with very conservative settings?
There are a lot of variables in milling. This is much more difficult than 3D printing. It might be possible to make one so conservative that almost any setup can use it, but, it would be tough.
I was having trouble cutting the crown test. I wanted some known good gcode to figure out if the problem was cutting code that was meant to be drawn or my setup.
It was my setup. Turns out set screws on the stepper shafts were loose.
That looks like what I asked for. Be nice to have one for wood or acrylic. I’m going to run it on scrap acrylic and see what happens. What could go wrong?
Full depth finishing pass? Shouldn’t that be like 10 or 20 percent?
asks the noob who didn’t know what a finishing pass was a week ago.
Full depth in Z but skims off just a hair in the X-Y direction. Going in one pass means it removes layer lines, if any (as long as your tool doesn’t have defects along its length). Shallow skim keeps the load low so you can get away with full depth in Z.
