Almost home! Got endstops installed and wired, motors wired, cable chains done. Also dialed in perpendicularity of router to 6 thou. Now just need to plug cables in to SKR board and begin testing. I used all the same cables from the burly build so it should just run without problems. Excited to cut some wood tomorrow.
Carved “token crown” into a piece of mdf which I then spray painted white and quick sanded. Didn’t have a pen mount and wanted to get the machine dirty anyway.
Crown is 6 inches wide and I only went a millimeter deep to check flatness of my setup. Happy with table flatness.
Final check after all adjustments complete. Five inch square is dead on as are the 1 inch circles. There is perfect registration on all objects. Thanks again Ryan for a great design. I am now going to put this puppy to work!
Well now we just need another person or two to finish their builds with the same results so I can release the hardware kits and recoup some of the R&D time and money.
On a CNC, I turned off the silent step features so I would always get full torque. There are a couple of neat “features” that don’t really make sense on a CNC.
I turned that off but did do 80% for the waiting torque or whatever they call it. I can’t imagine the non moving axis to need that much power. Who knows though, hard to test.
I remember a thread where someone thought it was reducing the torque on the Z motor while milling, because the Z was staying still. The Z was dropping while milling. I can’t honestly remember if that fixed it, or we just suspected it and we found something else.
I turned off the “StealthChop” option assuming that is what you are referring to in the Marlin configuration files. I spent most of the rest of the day trying to get Marlin to quit releasing the motors after the job completes. I turn my router on and off manually and when the job completes, the router drops to the surface if I don’t catch it first. I went through every configuration option I could find in the Marlin configuation files. I must have built and rebuild the firmware 15 times trying to find some relief, but never could get any of the X,Y, or Z axis to stay energized after the job.
I finally added gcode to move the router to back left parking spot and placed a block there to catch the router when it falls so as not to drive the spinning bit into the table.
Here is the last configuration I used that still didn’t work.
----------In configuration.h---------------
// Disables axis stepper immediately when it’s not being used.
// WARNING: When motors turn off there is a chance of losing position accuracy! #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false
--------In configuration_adv.h----------
// Default stepper release if idle. Set to 0 to deactivate.
// Steppers will shut down DEFAULT_STEPPER_DEACTIVE_TIME seconds after the last move when DISABLE_INACTIVE_? is true.
// Time can be set by M18 and M84. #define DEFAULT_STEPPER_DEACTIVE_TIME 1200 #define DISABLE_INACTIVE_X false #define DISABLE_INACTIVE_Y false #define DISABLE_INACTIVE_Z false // Set to false if the nozzle will fall down on your printed part when print has finished. #define DISABLE_INACTIVE_E false
.//In SD section #define SD_FINISHED_STEPPERRELEASE false // Disable steppers when SD Print is finished
define SD_FINISHED_RELEASECOMMAND “G0X40” // Use “M84XYE” to keep Z enabled so your bed stays in place
I am looking for suggestions as how to solve this though the parking option works ok,
