I am close to finishing my lowrider. I am trying to get an idea or have a place where people can share how they have setup their table. I notice some have dog holes while some have metal railings. There is probably no correct answer but what has been working for everyone? Is there a sticker of a ruler or something that can be pasted on so its easy to measure all the time.
I just use drywall screws (predrilled) and hold the work right down to the spoil board. If I am using something I can’t drill into (something that is already finished, but needs a carving), I screw down the scraps and they act as clamps to hole the part down. I have nicked a screw or two, and it hasn’t caused any noticeable problems. I would certainly start with that for 5-10 projects and see if you need anything more complicated after that.
You don’t have a lot of room under the gantry for the bit to reach the work, so clamps that stick up past the top of the workpiece have to be very small.
Drywall screws as well for some things. When I am doing a run of parts, which could be 30+ planks all with the same origin and length, I use a corner fence, and push clamps I printed my self using files from PWNCNC, I also bought some of these from them, support you know.
I T-tracked, recessed 1/8", my spoil board and can use t-slot clamps as well.
The PWNCNC files are on thingiverse
I agree with these guys. I kinda depends on what you are doing. I do not set up any sort of fixture unless I do something a lot. I typically slap things into different parts of the table to try and wear it kind of evenly. But for the YZ plates I use a set of screws that stay in the bed and I change sheets and snug it in place.
If you never throw sparks, you aren’t human.
