Hello guys,
Running into an issue on my Sunlu S8 build. I followed a great set of instruction and got it mostly running but still need to correct a few small issues I can’t get an answer on.
My SD card reader in the stock mother board broke apart and was not useable anymore so I purchased an SKR V1.4 non turbo board with 2209 drivers to replace. Installment went smooth and no major issues. I do however have a few I still can’t seem to tackle or find anyone giving similar problems.
First: My Z end stop will work great when homing, but during movement operations. If I accidentally move it too far negative, it slams into the board and the z stop seems to be ignored. Is there a line I need to change in the configuration files to change this?
Also, second issue and also pertains to the z axis. If it is too high and I try to home the axis, it will only go down so far and error out. Also looking for which lines would control this.
I never tried printing since the install, just working on the basic operational issues first. These seem to be the last 2 left and after 2 days on google, still no luck. If anyone could point me in the correct direction I would be very greatful ![]()
