Success on the first maiden tool path
need to work on cable management / routing, and the pcb needs a protective housing. Very excited. Me and a classmate of mine we’re able to run the crown path on some foam insulation we ducktaped to the table. Mechanical engineer and computer engineer @ Ole Miss.
Good to see you’ve got your machine moving!
You posted this in another thread, to answer that first can you elaborate on what controller you are using? You can absolutely run the machine without dual endstops (or any endstops), but the machine is much easier to use and more repeatable if you get all the endstops correctly working.
