Storage size mpcnc
Hi,
I have a simple question about the outer dimensions of the mpcnc. My plan is to build a little workbench where I can put my mpcnc on top to use it and under the working surface to store it, while I’m using my 3D printer. Now I used the calculator (https://jscalc.io/calc/Y1Db347ni9eckSKc) to calculate the table size.
My question is: Will there be parts sticking out of the table? Or can I use the table size as inner dimensions for the storage room?
Plan is to build the mpcnc to use with a dremel and foamboard perforator. Size: 800x600x100
Thanks!
Yea, the corner parts and belts will stick out, maybe half inch? You also need room for the wires and whatnot.
