Hi!, the MPCNC is done. The lowrider plastic parts too. I need to buy the electronics and steppers. Can I use the same motors as mpcnc (4.4kg)? or I need more powerfull motors?.
That is ~61 oz/in (if you are giving kg/cm). They should work fine.
The electronics can be 2560+Ramps 1.4? wich drivers? 8825 or 4988?
thanks.
If you have to buy motors anyhow i would get the 76oz.in or 5.5kg.cm motors. the price is negligible for the increase. I plan to use 84oz.in motors personally.
Edit: Ramps should be fine and the 8825 seem to hold up better in my experience.
