I’ve been working with my MPCNC for a couple of years now. I built it with a 12"x12" area, and it’s served me well.
But I’m working on expanding that now. I’ve built a new table for it, and have cut tubes, and reassembled everything, squared it up, etc.
I’m to the point of wiring things up, but I can’t use the old harnesses I got with my kit, due to the extended area. I have an old spool of 18AWG wire and some molex connectors I’d like to use up. The connectors, unlike the dupont connectors on the original, only fit one way, so I want to make sure I get the stepper motor wiring right.
I have 4 leads coming out of my Nema 17’s. Red, Green, Yellow, Blue. I’ve tested them by cutting the connector off, and holding wires together, so I know that Red and Green are a pair, and Yellow and Blue are a pair. I’ve done some reading, and see that these are usually referred to as A+, A- & B+ B-. Or on my Ramps board it’s 1+, 1- & 2+ 2-.
Does it matter which pair is A or which pair is B? Like, my RG pair could go to A or B, as long as BY goes to the other?
My understanding is that it doesn’t matter if you get the +/- swapped, but it does if you get the A/B (1/2) swapped. Obviously, I don’t want to damage anything. Do the +/- not really matter at all? Are all of these viable arrangements?:
R+G-/B+Y-
R-G+/B+Y-
R-G+/B-Y+
R+G-/B-Y+
Or do I need to be aware of the +/-, and if so, how?
If the motor is moving backwards, what gets swapped? Do As become Bs, and vice versa? or do the +s become -s?
Thanks
