Stepper plug measurement
If you have a stepper like this can you tell me the tightest this dimension can be, please. As in how far away would this wall need to be to still mount this stepper. Not a roomy dimension, like a snug dimension including wires folded over.
I have similar NEMA steppers, the distance you indicated on your diagram is 8mm, if the cables have to come out bent at 90° the minimum distance should be 11mm
I hope I was helpful
Yes, thank you very much!
Way more than I expected.
