Stepper Motor
Hi Everyone,
I was mistake brought 5 stepper motors and their mmpture rate is 1.7A so MPCNC need 2A recommended.
Can I use 1.7A stepper motor for MPCNC?
Wantai 42BYGHM809 stepper motor Specification:
  • Step accuracy: ±5%
  • Ambient temperature range: 20°C ~ 50°C
  • Insulation resistance: 100MΩ Min.50V DC
  • Dielectric strength: 500V AC for 1 minute
  • Step angle: 0.9°
  • 400 steps / rev
  • Voltage rating: 2.7 V
  • Current rating: 1.68 A
  • Resistance: 1.6 Ω per coil
  • Inductance: 3.5 mH per coil
  • Temperature rise tolerance: 80°C
  • Holding torque: 4200 g⋅cm
  • Detent torque: 260 g⋅cm
  • Number of leads: 4
  • Motor length : 4.8 cm
  • Nema 17 form factor
  • Weight: 340 g
Pretty sure those are stronger than the kit steppers.
If this is correct, it would translate to 58.327 OZ/in. The ones Ryan sells are 76 OZ/in which have a higher holding torque. Ryan’s are a 1.8 degree full step, but yours are a .9 full step, which would be a finer movement. You would also have to adjust your steps/mm accordingly in your firmware and/or CAM software.
As for how they would fare in real-world use, someone else with more experience here has to answer that.
The googled calculator failed me then…
Something is amiss here as according to the specs the KL17H248-15-4A (as stated) is a 0.9 degree per step motor with a 4.0Kg/cm holding torque, which is 55.55oz/in so unless the Chinese are playing games again I guess the ones Ryan supplies are not the ones quoted.
https://www.amazon.fr/Automation-Technology-imprimante-KL17H248-15-4A
specs
As to the OP, only trying them will see if they have enough torque in your build… They would be ok in a 3DPrinter or a laser engraver but with the increased loads from the cutter being dragged through the workpiece you will always be worried that at some point they will miss a step.
Well, looks like you were right anyway. :sweat_smile:
Depends on which Chinese site you get the stepper info from…
Thank Barry for advice about convert from g-cm to oz, Im learning to choose correct stepper motor for work with light duty or heavy duty tools.
I want to make sure the Wantai Stepper Motor can handle with Makita rt700c Trim Router to cutting Wood and aluminium?
It weight is 1.8KG
Makita rt700c Specification
https://leroymerlin.co.za/trimmer-makita-rt700c-710w-81431193?sfdr_ptcid=32806_617_517031420&sfdr_hash=5086b0ddceb11a689ecd6422a713e3eb&gclid=Cj0KCQjw9IX4BRCcARIsAOD2OB2KygCufk6Lm_XFQ6xhXSA5v_8PWO0D4cXteSG84zR2k4B2kH5FDMEaAvfiEALw_wcB
