Steel tubing headache - anybody from Belgium?
Hi guys,
I’ve been giving myself a headhache in the last few days, because for the life of me, I can’t source 29,5mm or 30mm or 32mm steel tubing in Belgium ! :tired_face:
That’s driving me crazy, because at this point it’s the only issue blocking me from upgrading my LR3.
Any belgians in here that could help me obtain some ?
And yes, I could order abroad and get it delivered, but I’d rather not pay more in shipping fees than in steel … I bought my LR3 tubes for like 30€, I’m not ready to pay 100+ for the LR4 :sweat_smile:
TIA !
Laurent
Tried your local electrical wholesaler? You should be able to get 32mm O/D metal conduit from them, although if the situation there is anything like here, it’ll be a special order item because electricians have taken to running 2 x 20mm conduits instead of ever using a 32mm… :laughing: Less things to keep on the van, I guess…
Thanks for your answer !
That, I found plenty of, but it’s all 1.2mm thick :unamused:
And Ryan is suggesting a minimum 1.3mm thickness, so I was hoping to find 1.5mm …
Jabimetal.at, Präzisionsstahlrohr. That’s where I got mine.
Thanks for the tip, Philipp.
Sadly, they don’t ship to Belgium :frowning:
Only DE, AT, CZ - that’s a bummer.
@kockie-nl can you help? You do have an address at the border, don’t you? :stuck_out_tongue:
I feel your struggle.
While I don’t have a real item to offer, I went through the same process trying to find the material. I recommend checking all the random shops that sell things that are not exactly marketed as pipes, e.g. Hand rails, fence posts, water pipes, exhaust shops, curtain rods. They are not always the best options, but could be worth looking into. Also don’t dismiss the option to call steel supply shops directly. There is a chance that they might have things in stock that are not in the websites.
that’s right, but then it’s still in the Netherlands and still far away from belgium.
Isn’t that next to each other? :sweat_smile:
just as Belgium and Germany are next to eachother
True… @pandax, if you want to make a road trip to Oldenburg and have a look at the Ghostrider, you can order them to my place. :smiley:
I bought stainless 30mm from Amazon.de (I’m in Denmark) Amazon.de
Delivery time was strangely long tho.
Thanks for the proposition @Tokoloshe ! I’ll keep it in mind … but I hope you won’t mind if I try to find something closer :grin:
I might have found something in France, for an (almost) decent price.
Hi @pandax,
I am also planning to build a LR4 after my current project is finished.
I found a metal supplier in Waregem which sells 30/2 mm tubing. Its called Faveere.
Kind regards
Hi Laurent, i am also in Belgium and i am also struggling with the same problem tot find it here. Do you find it?
@Mick I haven’t bought anything yet, no !
I currently have two leads - one is leboutte, on special order, and one is faveere, following @KevinTob recommandation.
I PM’d him, to know if he has a price, waiting for answer.
Drop me a PM, maybe we can arrange something together.
Ok, thanks, i try to send you a mp but not find how to do it. I am new in this Forum.
Hi,
Unsure if it helps : I’m considering to get tubes from idfmateriaux and they have a pick-up point at Roubaix (north of France/Belgium border) for steel products :
T.
If you click on a username it gives you the option to send them a message
PM’s received ! I’m at work, but will answer you both tonight ! :smile:
