I have the Primo MPCNC with a mini-Rambo board and the newest Marlin firmware.
I want to use the Start Gcode text in ESTLCam. I tried copying and pasting the example from the docs. I only want to Home Z.
When I run my gcode, it probes and homes Z. Then it moves to the beginning of the first Engrave and lowers to the correct spot and depth of cut. Then it stops there and doesn’t move. I don’t understand why it is stopping. Thanks for any help.
Here is my gcode:
;Project LHGnochi
;Created by Estlcam version 11 build 11.245
;Machining time about 00:44:34 hours
M05 ; PID, Stop spindle
G0 Z6 F500 ; Raise Z axis 6mm
M00 ; Wait for LCD button press
;Change tool: Ball Nose 1.5
G28 Z ; Home in order, w/zprobe
G92 Z1 ; Account for probe thickness (set your thickness)
G00 Z5.0000 F500 ; Raise Z probe off off of surface
M00 ; pause for LCD button press
G90
M03 S18000
G00 X0.0000 Y0.0000 Z0.0000 F2100
G00 Z5.0000 F480
;No. 1: Engraving 2
G00 X11.2361 Y76.4176 F2100
G00 Z0.5000 F480
G01 Z0.0000 F2.000 S18000
G01 Z-1.0000 F2.000 (It stops here)
G01 Y197.2500 F4.167
G01 Z-2.0000 F2.000
G01 Y76.4176 F4.167
G00 Z5.0000 F480
