We use 1/16th microstepping on all axis.
You need to check your motor specifications to make sure you don’t exceed their rating. But I suspect the 1A is going to be better. Is there a good reason to use these over the drivers in a rambo board?
My plan is to use the ESTLCAM ARDUINO Steuerkarte from the ARDUINO-Club. This card has a lot of options, but no hardware-driver for the motors, that is the reason I bought 3 TB6600.
Thank you for your answer, I’m looking now for “nice” hard blocks, or I must design them for myself.
Best regards
Thomas
Jeremy, the pic you posted looks as if the Rollers are not positioned correctly. I did the same thing and had xy issues as well. This is from assembly instructions: * This is showing the pairs for the X and Y axis. It should be one Roller and one RollerM. It does not matter which way the gantry rail angle is facing as long as it is facing the same as its counterpart.
So angle needs to be on same side… not opposite.
