It all started with Flitetest, where I “cut” a few planes on foamboard, and via the Needle cutter thread, I came here to discover CNCs…
So I decided to build my own CNC. Since I had no access to 3D printers, I got inspiration from Jhitesma Instructable contest co-winner design of the “Build a CNC Router” project, and started building my (bad looking/imprecise/flexible/nut sufficient for CNCing anything other than soap and polystyrene), with the result here.
While mechanics are inspired by the wooden CNC router, for the electronics, I MUST thank you all (especially Ryan) for the bounty of information.
(I found friends who could print 2-3 pieces (which helped some).
Later, I decided to “improve” and update it, by adding a printing extruder, and while it has BAD tolerances, it’s sufficient to iterate on itself by upgrading parts, but also now to the next step, by printing the MP3DP parts.
I’ll use the CNC to write the plans down on the MDF with a pen holder to make sure it’s exact, and will need to cut by hand, but I need to increase the working area, so that’s the next update to my “CNC”.
And of course, when I have a printer that has good tolerances, I’ll be able to finish the full circle, and print an MPCNC, which I may use to cut the plates for the Lowrider…
As for its name, it’ll be self-explanatory when it’s finished : my daughter gets to choose the colours since I didn’t let her paint the “horror” that is the first CNC…
(2 of my co-workers also will make their MP3DP at the same time )
