Solidworks and heat set inserts
For the solidworks users in here is there an easy way to use the hole wizard for heat set inserts? It would be nice if this was somehow built into the hole wizard. It might already be there, but I can’t find it.
They just require a specific hole size.
Yes. And sometimes you also need two different diameters. One for the heat set length and the other for the bolt to continue to pass through. It would be nice to have that feature in hole wizard.
