So went out to fire up the cnc and my tft35 is saying no printer attached.
I bought everything from v1 website, I have the skr1.2 pro with the tft 35 with duel endstops. It was working perfect before.
I’m using the firmware recommended from v1.
Went over all the wiring again and everything appears correct the only thing is the 5 black wire plug is always loose but has not caused a problem.
Anyone have any ideas why the printer wont attach?
I have not tried direct to computer as I cant seem to get ryans starting gcode to work as well with repetier host. So I stayed with the use of the screen and sd.
You flash the screen by adding the files to the sd card and resetting it. Same with the skr board. The nice thing is, you don’t need arduino or anything to flash standard firmware.
