Size and what printer
I am looking to do a cutting area of about 21D by 40W. Can the MPCNC be modified easily for that or should I look at a low rider? Also, I am very new to this and would like advice on the height needed on a 3D printer in order to make the parts.
Thanks,
Pete
Larger than 24" you are better off with lowrider. 3d printer 200x200 x200 mm should be able to print everything
cm? Inches? If inches, then LowRider.
Thank you.
Inches. Thank you.
Follow up question. Can the low rider be easily taken apart for storage?
The gantry can be easily removed from the table. Figuring out how to store the table will be your challenge, not how to move the machine to a storage spot.
Understood
Closing older topics, to fight spambots
