Sign & LowRider base
Sign is 15”x72”x1-1/4” white Oak. V-carved .200” deep, black epoxy filled milled off and sanded top with urethane.
And LowRoder base painted
Wow, that is huge!
How in the heck did you get texture on the surface of the epoxy?
Just poured the epoxy into the letters overflowing then surfaced the about .02 under surface to cut all the overflow off then sanded 150grit , 220 grit, 320 grit to finish the brushed 4 coats of polyurethane with seel wool between coats
I’ve looked and scratched my head a bit at this, and then realized it’s the brush strokes that have left the impression of wood grain on the epoxy… :sweat_smile: It matches the grain of the wood so well it looks like it has wood grain on the epoxy
The board is smooth I used triple thick polyurethane and yes it is the brush strokes you see under the bright leds I have in the shop in normal daylight it looks and feels fine.
Bummer, I liked the look of the grain!
Do you have to worry about the epoxy penetrating where you don’t want it? Like do you have to seal outside the letters with anything first? I’ve never done epoxy.
No do not have to seal wood. I just mixed up table top epoxy added color poured to over fill waited 30 min. used heat gun to pop any bubbles pretty easy. plenty of how to videos on you tube. I used table top epoxy because the depth was only .22 deep vcarve. Working on two more signs a business wanted WELCOME sign on each side of there entrance.
