Ok if I was going to walk into the Orange store today and get some glue, is there any particular brand you or anyone else would suggest?? I’ve been using this stuff for CA glue around the house, and it works great, but its not what I would consider cheap lol. And I cant walk into a store in town and buy it today. Have also used this one before too. But once opened the caps didn’t seal up well enough and the glue hardened in the bottle. So I have plenty of activator around just no glue LOL
So far the ones I have repaired with CA glue are holding on well. So I guess that is how I will move forward on the rest of the letters. So damn nerve racking not knowing for sure what the best course action is here. Wont know till its been on the wall for a few years and they are still in place, or its been up for a week and they are falling LOL
Edit to add. Someone else suggested silicone to attach them, but I cant figure out a good way to hold them while it dries and to keep them nice and tight on the letters. Some of the smaller letters don’t have a huge offset, so I need the lights to be real tight to not show from behind the main letters
You can use a couple of spots of CA and use silicone for the ultimate strength. I’ve seen people do that with wood glue.
I don’t have any experience with signs like that, or working for years. I have some CA glued abs parts on my RC heli and the glue is stronger than the plastic. It isn’t cheap though.
My go-to for stuff like this is plummers glue. Seems to stick to everything. Plus after opening it’s shelf life is good for months. Some of the automotive trim glues seem to be the same stuff. Sets up in seconds after putting pressure on it.
It’s too late I’m sure, but use a good brand general purpose construction adhesive “liquid nails” would work.
Better still is an andhesive designed for that type of use, something like Sikaflex 521. It might be overkilll, but it’s only overkill until you have to do it again and clean up the mess made by something that wasn’t quite right for the job.
If the backing of the LED is PVC - @larryk is spot on - use a solvent based plumbers’ PVC glue (get a clear one) - I have glued all my van components with it (with a few safety screws) and it does indeed weld the surfaces together.
The LED is in an IP67 “case” with a double sided tape on the back of it. The tape is practically useless. The only thing it sticks to good is the LED LOL.
Yep! clean off the tape with some IPA then give it a coat of primer to match the PVC cement - if the “case” is not PVC, it won’t work, so check that first!
Just had a Quick Look - your led is probably encased in silicone - just use a thin strip of clear silicone from a caulking gun and tape it all in place for half an hour or so. (or use dollops of hot glue to hold it temporarily while the silicone goes off)
No. Cant say I’ve ever heard that one. I will give it a try though! The one I normally use doesn’t have that issue. But as you see from the links its twice the cost without any accelerator spray lol
I really need to read what I type. I was refering to Pummers Goop. Sold under quite a few names. Goop plummers seem to be the current name I see on line now. A little of it goes a long way
Finally some more progress on the sign! Got the last of the panels cut out and picked up the painted letter. Put 2 letters on and wired them up real quick just so I could see how its going to look.
Still catching hell getting the LEDs to stick so I finally just drew up a little 3d printed part to slide on and hold them. Seems to be working well. Haven’t gotten to any of the small letters yet so we will see how that goes lol.
