Shattered feet replacements
Table fail ( 3d printed leg supports snapped ) resulted in mpCNC and support board falling a couple of feet. The vertical tube supports sheared along the print lines. Are printed feet available? The similar topic “new feet??? stl???” is unanswered.
The STL files should be available wherever the full kit is. Thingiverse, Prusa, etc. Poke around the Docs link. It should have the info there. Just be sure you get the correct version for your tubing. “C"onduit - 3/4” EMT conduit. “J"umbo - 1” OD SS pipe, "F"oreign - 25mm OD pipe.
https://docs.v1engineering.com/mpcnc/PParts/
The post you referenced is also a three year old post re: the “new” burly styled feet. They are part of the current set as well.
Understand obsolete feet referenced.
Can I purchase feet alone ( after mine broke… ) ?
Missed this reply earlier. Understand you do not offer “feet only” package. Have STL files on hand. Have Files Will Make.
@Ryan, I think this is a question for you.
Feel free to print your own, If you want me to sell you a set; PM or email me so we can exchange some details.
Delay in getting 3D printer. Would like to inquire about you printing broken feet ( cost ? )
Do not have PM or email address for you.
