Set default Jog distance to lowest value
I would like the default distance selected to be 0.1 mm rather than the 100mm. I seem to forget to change from 100mm at times and have crashed my axis due to operator error. This is not a complaint about the software just a “Make it safe for this type of operator” question. I can then select the distance I want if forgetful. I have looked in preferences.json and the settings page but not found anything.
Thanks
I’m assuming this is for WebUI v3. Yea, you’re not the first person to ask for that. I’m not sure 0.1 is a good default but 100 isn’t either.
You could try my virtual joystick jogging extension as an alternative jog panel.
I have some other WebUI modifications I was working on. When I find some time, I’ll see about changing the default or making it configurable.
Thanks for replying Jason, it sounds like their is no configurable setting yet.
