SD Card Files Connected to Windows Network Drive
Good Afternoon!
I am working on macros and figuring out the best workflow for using this machine. I am new to fluidNC but not new to the CNC world, I have built a CNC back in the day using GRBL hat with an arduino and various other machines. One thing that I am finding annoying with fluidNC is that I have to drag and drop the files into the webUI that I want to run, adding another step that I could mess up. Especially with no built in Gcode preview in the webUI. So I am wondering if there is a way to setup a network drive for windows that can view the files that are on the SD card so that I could save files directly from my CAM software to the machine. I would also be curious on what other peoples workflow looks like.
Thanks!
Hmmm. I don’t know of a good way to do that. I know in Linux you could write a script to watch a folder and then at least call something when a new file showed up or was modified. Then you could probably use a curl call to upload the file. But I have no idea if the curl call is possible. And no idea if windows can do something similar.
What about having two sd cards that you move with you?
You can use curl with FluidNC. I do it when working on WebUI extensions.
http://wiki.fluidnc.com/en/features/wifi_bt#upload-with-curl
I was thinking similarly with a directory watcher which you can do on Windows. That feels a bit fragile though.
At one point I had it so you could right click on a file and send to the SD card but I don’t use that anymore.
Hmm, thanks guys. I think I will just use a PowerShell script with the right click menu for now. Kind of a bummer there isn’t a cleaner setup. I would use openbuild’s control software since it has everything I want, but streaming Gcode though it seems to be laggy and not as smooth as the SD card.
Yea you could try a different gcode sender like UGS which has good FluidNC support.
I avoid gcode senders since the connection seems like another possible point of failure.
You can also try the tablet extension for the WebUI (exists for V2 and V3) which includes a gcode preview. I don’t use it.
My solution for the time being is a powershell script that looks at a folder I tell it to and if there are any changes in the folder it uploads that file over curl.
Hello Garrett. I might be wanting to do the same sort of thing. I have my cnc in the garage, but my design computer is in the basement, so I’ve been dropping my gcode to a SD card everytime I want to run something, then manually carrying it to the garage and putting it in the cnc controller. Are you saying there’s a way for my design computer to “see” the SD card in the cnc controller and drop a file directly into it using the wifi? I know the two can see each other on the network because I got them talking to each other using the UGS sender.
Well I was not able to get my program to read what is on the CNC, and honestly I dont know if that is possible. But I am able to send programs to the SD card with the program that I uploaded previously. Haven’t had the time to iron out all the wrinkles but it works well enough for now.
Same here, I tried a bit with UGS, but couldn’t get it to see the SD card. It saw the control board, but not the SD card within the control board. I downloaded your program, but I don’t know how to actually work it. Could you explain how to work it, I’d like to try - sorry to be a bother. I bought my first computer in 1978, but I don’t know about Powershell, ha.
