runs fine in manual starts and stops when run crown test
Maybe some assembly pictures please? Your issues are new to me. Not standard in any way.
Take off the steppers and test them, no extensions. I am not sure where to start.
All right figured out that I was using the wrong firmware to flash the board the whole time. So I flashed the original board with correct firmware everything works as it should. I reran crown test and discovered that it is not stopping just moving so slow that appears that it is not moving. So how do I speed the test up running from my laptop not card?
Use my Gcode to test with.
That worked Test looks great! Ok I have learned allot in this process and thank you for being my sound board while I worked threw this problem. It turns out I was the problem!
