Round bar in Australia
No affordable Electrical Metallic Tubing (EMT) in Australia; PVC is used for electrical conduits.
Down the rabbit hole we go:
1.2 - 1.6mm wall thickness recommended (.049″-.065″)
Stainless is recommended but slightly overkill. Steel works well, only concern might be bearings could leave marks in the surface of the round bar over time. You can simply rotate round bar to compensate. Square tube or rectangular half section (RHS) as we call it is not recommended.
304 grade stainless is for general use.
316 grade stainless is for marine use, offers excellent rust protection in salt climate and is slightly more expensive.
Chromium in both 304 and 316 offers rust protection. Molybdenum in 316 offers additional resistance against chlorides and chlorinated solutions. Hardness is same between 304 and 316. 1 inch stainless round bar is often used in outdoor railing.
https://www.australwright.com.au/products/stainless-steel/stainless-steel-tubing-tube-fittings/
AW As Welded
AWP As Welded, Polished
AWA As Welded, Annealed
AWAP As Welded, Annealed, Polished
CW Cold Worked
CWP Cold Worked, Polished
Round tube 320 grit finish standard, 400 grit for 316 only on request.
Common polishing finishes: satin, mirror or milled (not polished)
https://www.blackwoods.com.au/part/06333810/tube-ss-rnd-ann-316-254mm-odx16wtx6m
  • Grade 316
  • 25.4mm (1 inch) outer diameter (OD)
  • 1.6mm wall thickness
  • Manufacturer Austral Wright (product code 50008000)
  • AWP, 320 grit polished, satin finish(?)
  • 6 meter length
  • $90.90 AUD per length ($65 USD)
Suggestions what pipe to use / where to purchase in Australia (Far North Queensland) appreciated, thank you.
You don’t need the fancy stainless, unless you’re running your router on the beach, then send pics! Doesn’t matter if it’s extruded or welded, just don’t run a bearing on the weld. Surface finish also doesn’t really matter at this point either, as long as you can run your hand across it, and it doesn’t hurt anyway. Basically whatever is the cheapest with the correct outer dimension and wall thickness will work.
Bunnings for me in WA … Metal Mate 25.4 x 1.2 1m Galvanised steel round tube @ $5.32. 3m lengths also available.
