Recommended Laser for Newbie on Primo
I am a newbie on the form and currently finishing the build of my Primo. I would like to add laser soon. I want to engrave and cut 1/8” or less thick material.
  1. Can you recommend a great laser for a beginner?
  2. Will the Jackpot 3 control board work with the laser or will I need to purchase a dedicated control board for the laser?
Thank you all for the help.
Jackpot 3 works with a laser (I have one on my JL1 laser engraver.)
What do you plan to use the laser on your Primo to do?
This would influence what folks may recommend to you. A good cutting laser is different than a high detail engraving laser.
Hello MakerJim and thank you for responding.
My plans for the laser is detailed engraving and cutting up to 1/8” plywood. I hope that helps.
Actually after thinking about it and reading other posts. I feel like the best plan would be to use the laser for engraving and the router for cutting.
I have the LaserTree 10W module kit. The kit comes with a sliding mount (that can be adapted to @DougJoseph’s kinematic tool holder for the LR3/LR4 - for the Primo you may need to design a mounting base), and an adapter board (needed if using a separate power supply). The laser has an air assist nozzle. I attached my shop air hose with the pressure regulated to around 30 PSI.
It’s pretty inexpensive (on sale at $139 USD - without the kit it is $126)
I ordered the 24V model (also comes in 12V), and run both the controller and laser from the same power supply (adapter board not used), but the stock V1E power supply is under-powered to run both, so I bought a larger power supply.
It engraves wood very nicely. I haven’t used it for cutting, but it claims 8mm plywood/5mm MDF in a single pass. YMMV. They also have a 20W model that should cut pretty well, but it has a wider form factor that may or may not mount well on the Primo.
Here’s some pictures of it on my LR3
