Uh Oh, so I was just looking at the new Ramps fw and for some reason I though the ramps was set to use 8825 drivers by default.
When I made my mpcnc, I just loaded the hex file and did not look.
The new fw shows the config to have 4988 drivers in it, so, that means that it is what is in the Hex file, correct?
Now, here is the real question, would my machine work if I have 8825 drivers, but the fw is for 4988? And if so, is there any harm?
I have a new ramps board that I will be hooking up soon, as I ruined mine with manual moves. So I think i need to make custom firmware for my set up, correct?
The V1 maintained Marlin firmware is definitely DRV8825. I used it with DRV8825 drivers as a starting point for a non-MPCNC project. Not sure what role the config.ini file play in the build.
