Can not believe I didn’t think about the floated ground! Thanks Ryan I’m going to try all of that and get things moving again! Not gonna lie I told my wife I wouldon’t break anything (she wanted to use the spindle to cut some stuff…) so I’m eager to get it back to basic operation!
Ryan,
I have refreshed the base firmware from : GitHub - Allted/Marlin: Optimized firmware for RepRap 3D printers based on the Arduino platform.
Here is the output from the serial monitor:
start echo:Marlin 1.1.5echo: Last Updated: 2017-08-28 12:00 | Author: (none, default config)
echo:Compiled: Dec 20 2018
echo: Free Memory: 5508 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echo: G21 ; Units in mmecho:Filament settings: Disabled
echo: M200 D3.00
echo: M200 D0
echo:Steps per unit:
echo: M92 X80.00 Y80.00 Z4000.00 E500.00
echo:Maximum feedrates (units/s):
echo: M203 X300.00 Y300.00 Z5.00 E25.00
echo:Maximum Acceleration (units/s2):
echo: M201 X3000 Y3000 Z100 E10000
echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
echo: M204 P3000.00 R3000.00 T3000.00
echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00
echo:Home offset:
echo: M206 X0.00 Y0.00 Z0.00
echo:PID settings:
echo: M301 P22.20 I1.08 D114.00
Unfortunately with just the XYZ motors connected I get no movement on G0 commands.
Some days you should just NOT mess with things, new born baby sleep brain is one of those times!
I appreciate all of the help and explanations!
That is not my firmware. Have a look at the firmware page on how to use github and select the correct firmware.
Well im just gonna see myself out… Man I thought a month of paternity leave would be a good time to dig in to this and get a laser up and running… you really need all your brain cells and sleep! Im sorry for the dumb questions… im back online. Thanks Ryan. I have no idea how I got from yours to base marlin… Thanks again. I think I will just work with M106/M107 for laser control for now… maybe after a little more sleep ill tackle M3/M5, right now im just glad to be back online.
Well the Xmas rush seems to be tapering off a bit. Once I clean up around here and get a little ahead I will be digging into the laser situation. Hopefully I can make it a little more straight forward.
