Quick questions about Lowrider 3
Anyone have any sort of good comparison data to other CNCs in this sector? I mainly ask because I had a MakerMade M2. Needless to say, I wasn’t super happy with it. It felt like it was always broken and the chain driven system left alot to be desired.
Fast forward to now and I have just gotten back into 3D printing. I bought a monoprice maker select back in 2016. I work in tech/infosec so I enjoy tinkering. I now have a MK3S+ and Mini+. Then I came across the lowrider. It has peaked my interest and I have started my printers printing the parts. I found during the pandemic that I enjoyed doing some woodworking and I thought this project could combine the two.
Any information from a feeds and speeds comparison? How does it do with hardwoods like walnut and cherry?
If you look around the forum you will find loads of threads about those questions. There is also a “Things you’ve made” category that shows pretty well what’s possible. :slight_smile:
Thanks. I was just mostly curious on how this compares to the M2. Is it slower/faster/more accurate/etc…
I don’t know the M2 and I am not sure how many do. This is my “standard” list, for example 2000mm in hardwood with a 6mm. I think I could go faster, but am not sure about that, never tried (with an MPCNC that is). The DOC is higher most of the times, with the 3.175 I go 4.1mm deep when cutting 12mm wood for instance. Hope that helps more than the last comment. :smiley:
This is amazing! This really helps!
If you’ve got specific questions about the endmills, just ask, since they are in German. :slight_smile:
Here is a video with 11mm depth aluminium in one go and trochoidal: Cutting Aluminium - YouTube It does flex a bit, but I just wanted to try whether it works. The pieces came out great anyway.
8000mm/min planing an MDF board: Vacuum Table 8000mm/min. Neeeeeeeeooooooooooow. - YouTube So faster is always a possibility, but I use TB6600 drivers, don’t know if the others can do that.
That is pretty amazing. I would love more information on your setup. I know it is a MPCNC, but what is the size that you went with? Seems like a pretty great setup!
I will probably have questions once I get everything printed and start building the lowrider.
Here is the build thread for the Primo. The lowrider is in the making under the name Froschkönig. :smile:
Do I need to reprint this? These are the xz plates. Looks like the corner lifted up on these. I assume the answer is yes
When I was getting started with using my first LowRider (a v2, and I’m now on a v3), one of my biggest areas of questioning was about feeds and speeds. I know quite a bit of info is available on the internet just by googling, but I wound up buying an app dedicated solely to calculating feeds and speeds, called G-Wizard by CNCCookbook. Each time I run the numbers for a new project, I’m always amazed out how fast and how deep is tells me to go, and then similarly impressed that the LowRider 3 can indeed carry the mail at the suggested speeds!
Looks interesting, they even have a Lite version you can use indefinitely for 79$ if your spindle is <2hp: G-Wizard Lite Plans and Pricing
I think that plate is critical for the alignment at the end. So I would reprint it, or else be ready to shim it.
Thanks! I did.
