Questions on Table top Zen XY
@jeffeb3
I have tried to figure this out using the onshape info you had provided, but I’m not very well versed in using it.
I have a question about how the bottom glass ( the one closest to the magnet) was mounted.
It looks like it is attached to the bottom of the plywood. I also can’t tell if you routed out a portion of the plywood to form a pocket for the glass to sit in. What did you use to secure the glass and what did you use to seal it. Thanks for your help.
I used fender washers and screws to hold it in a close sized cutout. From there I actually used some wide tape to seal the edges from the baking soda getting out.
Does that make sense? I thought I had some pictures of the washers up but if you remind me earlier tomorrow I can get some new pictures.
Sorry Ryan… I didn’t even think or look at yours … I got fixated on Jeff’s and only looked at what he had done. I’ll go through yours later today. Thanks
