Prusa Firmware 8.0.0 - Beware!
Let’s not kid ourselves, I am kind of a fanboy, even though Prusa has burned me yet again with missing support for other nozzles sizes than the standard with the INDX (even though Bondtech sold HF0.6mm and 0.25 and 0.4 STD nozzles, they are still not supported officially). They did so with the MMU3 as well, but at least they had the excuse that the nozzles weren’t specifically made for this printer.
Okay, rant one aside for rant two: With the firmware 8.0.0 Prusa has introduced a new feature. M204 F120. What does it do? I am glad you asked:
New M204 F filament acceleration limit, enabled by default
The printer now limits filament flow acceleration to prevent sudden extruder speed changes caused by pressure advance. If the limit is exceeded, the printer reduces the acceleration of the entire printing move, including cornering speeds near extrusion moves. Travel moves without extrusion remain unaffected.
The limit is controlled by M204 F in mm/s² (e.g., M204 F120). The default is 120 mm/s² for all printers except the MINI (50 mm/s²). Use M204 F0 to disable it. The setting resets after a restart and can be checked using M204 or M503.
Sounds okay, more safety, can’t be bad, right? WRONG. WRONG WRONG WRONG!!!
These are the estimated and total print times of the braces I have printed a dozen of times before:
Printing time 3 h 30 m 43 s
Estimated printing time - normal mode 2 h 8 m
Notice something? That’s more than 30% longer. This also happens with HF0.4 nozzles, but since they aren’t extruding that quickly you won’t notice. I notice. I print parts as a side gig.
I have been wondering for days why prints took so long, but always thought I was getting old, not paying attention. Shame on me! I was fooled by Prusa!
The best thing: since it is now baked into the firmware, all the old gcodes deal with it. Guess what, also the new ones! The estimate in the slicer is still 2h8… So it does not calculate the M204 there. Why the … would they do that and not calculate it. Make it more confusing, I am begging you.
You can add M204 F0 to the start gcode at the very end to disable it. Absolutely do so. It persists until a printer reboot. Since I am shutting down my printer for the night, I now have to redo all my gcodes to include the starting gcode. Why not make it a toggle in the firmware? Huh? Too easy, you say? Well, cool, let’s gimp our customer’s printers now that Bambu announced a machine that can print different materials, different sizes of filament and has different nozzles sizes from the get-go that actually work. Let’s just make our product worse.
We all know I am going to buy the next public beta test from Prusa again. I am asking myself why I am doing this.
I am kind of mad at the moment.
Well, from my perspective, you’re the test rat that will keep me from repeating the same frustrations on my own. So, thank you for that :slight_smile:
Yes, this bit of Prusa behavior is the thing that most infuriates me about Prusa.
Prusa Tommy is on it: https://www.reddit.com/r/prusa3d/comments/1xnyueo/print_estimates_off_with_800/
Looking at the topic, I’m reminded as to why I always pronounce .0.0 releases of just about anything as “point uh-oh.”
