I am trying to make a pendant for my Jackpot controller, using Bart Dring’s design. I am trying to upload the firmware to the M5Dial, but I keep getting com port failures. I have tried several suggestions that I have found on the web, not specifically for the M5Dial, but this hasn’t worked so far.
The terminal log is:
* Executing task: C:\Users\alanp\.platformio\penv\Scripts\platformio.exe run --target upload --environment m5dial
Processing m5dial (platform: espressif32; board: m5stack-stamps3; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/m5stack-stamps3.html
PLATFORM: Espressif 32 (6.9.0) > M5Stack StampS3
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 @ 3.20017.0 (2.0.17)
- tool-esptoolpy @ 1.40501.0 (4.5.1)
- tool-mkfatfs @ 2.0.1
- tool-mklittlefs @ 1.203.210628 (2.3)
- tool-mkspiffs @ 2.230.0 (2.30)
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 38 compatible libraries
Scanning dependencies...
Dependency Graph
|-- JsonStreamingParser @ 0.0.0+char-1.0.2.sha.846bc19
|-- GrblParser @ 1.0.0+sha.9108f54
|-- M5Unified @ 0.2.0
|-- M5Dial @ 1.0.2
|-- M5GFX @ 0.2.0
|-- LittleFS @ 2.0.0
Building in release mode
Retrieving maximum program size .pio\build\m5dial\firmware.elf
Checking size .pio\build\m5dial\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [= ] 8.7% (used 28640 bytes from 327680 bytes)
Flash: [== ] 18.4% (used 614709 bytes from 3342336 bytes)
Configuring upload protocol...
AVAILABLE: cmsis-dap, esp-bridge, esp-builtin, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esptool
Looking for upload port...
Auto-detected: COM7
Uploading .pio\build\m5dial\firmware.bin
esptool.py v4.5.1
Serial port COM7
A fatal error occurred: Could not open COM7, the port doesn't exist
*** [upload] Error 2
============================================================ [FAILED] Took 10.03 seconds ============================================================
Environment Status Duration
m5dial FAILED 00:00:10.032
======================================================= 1 failed, 0 succeeded in 00:00:10.032 =======================================================
* The terminal process "C:\Users\alanp\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload', '--environment', 'm5dial'" terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
I have tried changing com port from com 7 to com 2, with the same result.
Does anyone have any suggestions (apart from launching it through the window)?
