I’m not sure whats going wrong, it could be the gcode, it could be the firmware but right now instructions are being interpreted as at least 10x there normal size, I did a little circle as a test and its coming out as a pretty huge one right now in testing. Anyone got any hints?
; Generated with MatterSlice 1.0 ; filamentDiameter = 1.75 ; extrusionWidth = 0.4 ; firstLayerExtrusionWidth = 0.4 ; layerThickness = 0.2 ; firstLayerThickness = 0.3 ; automatic settings before start_gcode G21 ; set units to millimeters M107 ; fan off M190 S50 ; wait for bed temperature to be reached M104 T0 S210 ; start heating extruder 1 T0 ; set the active extruder to 0 ; settings from start_gcode G28 X0 Y0 Z0 ; home all axes G1 Z5 F5000 ; lift nozzle M109 S210 ; set the extruder temp and wait G28 X0 Y0 Z0 ; Home Z again in case there was filament on nozzle G29 ; probe the bed ; automatic settings after start_gcode T0 ; set the active extruder to 0 G90 ; use absolute coordinates G92 E0 ; reset the expected extruder position M82 ; use absolute distance for extrusion ; Layer count: 119 ; Layer Change GCode ; LAYER:0 M400 M107 G0 F9000 X115.534 Y94.367 Z0.8 ; TYPE:SKIRT G1 Z0.3 G1 F1800 E0
here is the first setup bit of code for the thing. it seems normal.
edit: after moving the X rail ‘10m’ it seems to have moved ‘26.3m’ instead so there is something wrong with the firmware it seems.
Are your steps/mm set right? What kind of driver do you have? Do you have it set for the wrong microstepping? If it’s a ramps, then install all the jumpers under the drivers.
motors are 17hs19-2004s1
Unsure what the drivers are but I included a picture of them.
all the jumpers are installed.
I ‘think’ the steps are 200 per rotation (the defaults setup in the marlin files I downloaded here) but there quite a bit off I tried adjusting it just measuring the difference between movement and result and found a difference of 24.2 after doing it very carefully and offset the motion by that (10/24.2 * 200 = 82.64) and it seems fairly accurate now, but I have no idea what I’m doing other then guess work like this!
Those look like a4988s, but it’s just a guess. They max out at 1/16th microstepping. I think thateans you should be at 100. It will be a round number. It could be 80 if you had a 20T pulley instead of a 16T.
I guess you didn’t get your parts from Ryan. You’ll need to know what you put in there. His firmware is matched to his parts.
I figured as much, I am using a 16T belt. At least I believe I am, I’ll check to be sure. If it is likely a ‘round number’ its probably 80, because after measuring test prints its pretty damn close for eyeballing it.
10 -> 26.3 seems awfully close to in -> cm. Sure of your model size before slicing?
