How dialed in does the printer really need to be?
So I’ve only just started learning 3d printing and slicing software. Since my experience is limited I don’t really know what makes a good print or not.
I just printed off the Z_Lower_Burly more of as a test than anything. I used the generic 'ol white scrap PLA that came with the printer. As far as I can tell the print came out pretty decent for a first try. I choose the Z_lower so I could test the fit of the bearing, the hole for the bearing is just slightly larger than the bearing, not a press fit. There is no wiggle room for the bearing but it will easily fall out when the part is turned upside down. How tight of a fit should this be??
Are there any other parts litmus tests that I can perform to know if my printer/slicer is up to par?
This seems to me like an ambitions project to take on as my first 3d printing project, but… whatever. Gotta learn somehow.
Any comments on my settings?
Creality CR-10 Mini
Slic3r 1.3
55% infill, honeycomb <- what infill pattern do you guys prefer?
0.26 mm layer height (0.4 mm nozzle) <- per Ryan’s posts
3 perimeter shells, 3 top and bottom layers
All print speeds set to 30 mm/s <- per Ryan’s posts
Auto extrusion widths
200 C extruder / 60 C bed
4 mm retraction
45 mm/s retraction
Wipe while retracting ON <- really not sure about this one, or any of the retraction settings for that matter. Probably causing those blobs visible in the pictures.
