Welcome @T-stone! Recommend ensuring your printer is well calibrated for dimensionally accurate prints to help maximize joy during your build, and, minimize waste of your time and material. Strongly recommend using Calilantern.
If the docs are not loudly shouting out this sunny happy path to success, please let us know so they can be tweaked.
What nozzle size, and layer height are you using?
Personally used 3 walls with 0.6mm nozzle, 0.66mm layer width, 0.32 layer height, plus alternative layer infill wall. Doc recommended infill percentage plus 10% because extra print time is small fraction compared to time spent using the machine.
https://docs.v1e.com/lowrider/#diy says 3 walls. Also says up to 80% width to layer height ratio, but, lower more conservative ratio closer to 50% isnโt uncommon here.
