I’ve recently started to tune up my Primo after neglecting it this past years due to the high garage temps. There are a few parts that have cracked so I’ve replaced any that are critical and plan to replace the others when they get to a point that impact function.
One area that I’ve always wanted to mess with is maxing out the feed rate for my build. I’ve seen a couple videos where they bump up the feed rate until the machine starts skipping steps. So far I’ve maxed out at 800mm/s. This is based on some pretty crude stopwatch timing. I have not been able to get it to skip steps, I just don’t see any meaningful time reduction beyond that value.
Now, I know it’s most likely not hitting that speed for my build size, so I probably need to increase my acceleration as well. Has anyone tried this on a Primo? I would like to see if I’m heading in the right direction. Any guidance/input would be greatly appreciated.
