Primo J Core Clamp Bearings and Squaring
Squared everything up as best as I could, within 1/16th of an inch. Started putting the belts on today and I think I’m the first one to mess it up. The nut trap on one of the upper belt holders must have broke and now I can’t get it out. Any ideas? I’ve tried pulling on the screw in different angles while trying to unscrew it but it won’t catch anything.
Can you pull the screw out and push the slide out from the screw hole with a tiny poker or nail?
No, the screw is still stuck in the nut.
Gotcha.
The only hope is pulling the slide from the other side and getting the nut to catch again. I pull on the belt real hard.
If the belt broke out, best you can do is cut the head of the screw off and push it through.
Looks like I will have to cut the screw then. The trap feels like it is broken but I will give it another shot.
