I am on the Z Core section of the build and have inserted the clamp, bolts and bearing. The angles match. I am following the steps to slightly tighten each clamp up. However I get to a point where the bearing are touching and can slightly spin with fingers but I can rock the clamp a bit. I am guessing there should be no play on the clamp but just want to make sure before I continue tightening them down
