I shared the following details in a private conversation with a maker building his own LR3, and thought it might help others too, to better gauge where to position your Y rail blocks for your given table situation.
So, one crucial bit of dimension to know, is the distance taken up by the linear guides (that are attached to the YZ plates) and their slide bearing trucks (that are attached to the XZ plates). If those items are all according to spec, the total for them as a set, should be 13mm. (You could measure in the real world to confirm.)
Once you know that number, you can get the sum of YZ plate thickness x 2, XZ plate thickness x 2, gap of 13 mm between those two plates x 2, plus your proposed tube length, to get an overall number. For instance:
YZ plate thickness = 12.7 mm x 2 = 25.4 mm
XZ plate thickness = 6.35 mm x 2 = 12.7 mm
Gap of 13 mm between those two plates = 13 mm x 2 = 26 mm
Proposed tube length = 1422 (or 1425) mm.
Thus, using 1422 it would be 1486.1 mm.
Or, by using 1425 it would be 1489.1 mm.
The above would be total width of your LowRider from outside edges of YZ plates. Does not include motor “stick out,” etc.
Another crucial bit of dimension to know, is the distance from the center of the Y rail to the outside edge of the YZ plate on that side. That number can vary based on the thickness of your YZ plate. It can be calculated by the “known” distance from the center of the Y rail to the inside face of the YZ plate, then add on the thickness of your YZ plate. The “known” distance from the center of the Y rail to the inside face of the YZ plate = 26 mm if my 3D modeling mockup of the LowRider is correct.
Armed with this, you can then layout your location for the Y rail blocks to be attached.
PS: because I do a lot of remixing and mods, I dropped almost all the printable models of the LowRider into SketchUp and arranged them to resemble an assembled LowRider. This has been invaluable to me.
