I made some parallel to series boards on OSHPark if interested
Don’t need to hack up your wiring anymore…plug and play
Those boards look pretty slick, those connectors aren’t the perfect fit for the plugs we currently use but if you take off the white shield after soldering they fit perfect.
I have some new wiring harnesses on the way, wired in series, but I might try yours out as well and see what fits better. Thanks for that!
Hello, I am planning to build one MP CNC, and stepper motor/driver is my first concern.
I read carefully all thread, but I don’t find anything about the link between stepper motor, driver and power supply, but if you understand that it is easy to choose what you want to do.
The driver provides electrical power to the coils of stepper motor in right order and allows limiting the maximum current. The wiring (wires and connectors) and the motor have impendency that limit the rising time of current. The rising curve is linked to the tension of power supply.
Due to that if you power only one stepper with a driver, the rising time of current is nearly linked to the difference of voltage between the power supply and stepper motor voltage per phase.
If the motor run slowly, the rising time can be forgotten, but when you increase the speed this is not the case and this rising time result is to lower the average current of each pulse and decrease the torque of motor stepper.
If  you add another stepper motor in serial (without any other change) the difference of voltage between the power supply and  the  2 stepper motors voltage per phase decease also (can be negative according the type of stepper motor) and due to that the rising time is bigger and the average current lower and torque lower.
If you put in parallel, the first impact is to nearly double the current, but there are other things to take into account: wiring, and motors. Even you take care to have the same wiring for the 2 motors (length/ section / connectors…) each motor are slightly  different , and the current in each of 2 stepper motor are also slightly  different, and this is difficult to manage.
Due to that “industrial” solution is to use one stepper for one stepper motor and to measure the real current in both motor (with scope) and adjust the 2 stepper motor at the same current.
In practice:
They are not excattly the same:
They are exactly the same. The drawing is a representation showing the coils separately. The picture is the real world version of the drawing, for those that have my parallel wiring harness it is easy to copy that and make it series.
Hey,
I just had to put in my 2 cents here.  I’ve had my unit up and running about 5 months, and doing daily runs on it about 3 months. Ted,  thank you for a great design.   My unit is 3x4 foot and is highly Modified.  I would post my mods, but, I just don’t have time to.
First mod is I put mid way supports on the outer rails on both X and Y axis. But, I wasn’t happy that the gantry had too much flex.  So, I made an Extreme mod of the Gantry.  First, I put 2 pipes on both the X and Y (only on the gantry, not on the outer fixed rails). I kept the center rollers on the outer rails the same - only one pipe is attached to the center rollers, the 2nd pipe is screwed to the main pipe.  On one axis I put the 2nd pipe on the top, on the other axis i put the 2nd pipe on the bottom.  The pipes are screwed to each other, and i used 4 screws - one at each end and several along the length.  The two pipes - one on top of the other, has a lot more stiffness.  But, due to there now being 4 pipes going to the Z gantry, 2 on the X and 2 on the Y, i had to totally redesign the Z axis and gantry.  I went with HEAVY Duty - using 3/4" thick oak plywood plates, one on top, one on the bottom.  And redesigned the rollers to account for the 2 pipes on each axis.  It is heavy and bulky, but, it is SOLID.  With the dual pipes on both X and Y I still get flex in the gantry, but, far far less. Previously I just had to put a slight pressure on the gantry and get very noticeable flexing.  Now I have to exert a fair amount of force to get a slight flex.   Much more solid.
At the same time I switched to an 8mm lead screw rather than the 5/16 threaded rod.  The Z is much faster - can run it at 2000 mm sec.  BUT - with the lead screw there isn’t much resistance, so the weight of the motor would make the Z axis drop straight down when the stepper motor would turn off.  I ruined a number of bits and have holes at my home position and all over the spoiler due to the motor just dropping straight down.  Finally, my latest mod was to add a Counter Weight system to my Z axis.  That adds another 6+ lbs to my gantry, but, so far i have not seen any issues with that.  The counter weight added some bulk,   but, it has taken all the weight off the Z axis motor.  With power off I can literally spin the Z axis and just as easily move the Z up or down - freely.  And, yet, it no longer drops on it’s own.  (Like I said, my unit is highly mod-ed).
At one point I had updated the outer center rollers with the newer design that has built in braces to keep it from bending. But, I had only updated the Y axis (because I had damaged it at one point). The pressure of the timing belt on the older center roller caused the motor plate to bend after a while. But, like I said, i had only replaced them on the Y axis. After running the system for several months - all of a sudden it started messing up on my v-carve work. I finally found the X axis was skipping. It was binding. With power off I could freely push the Y axis, but the X was binding. In the end it wound up being the older Center roller, the X axis that i hadn’t updated - it was leaning over. That slight tilt was causing the belts to bind up enough to make it skip when it was carving. I then printed the newer center rollers and that took care of the binding.
But, before I figured out what was causing the X to skip, I looked into what I could do to up the current to my motors and was looking at wiring separate drivers for the X Y motors rather then running them in parallel. I am using 84oz torque NEMA 17’s that max at 2 amps. But, the drivers max at just over 2 amps as well. I had set the trim pot on the X Y drivers at 1.1 volts, so they would output 2.2 amps. While researching what i was going to do, i found this thread. Good thing I did.
It was so easy to change over to series on my design where the wires come out of the cable chain on the center roller, i just disconnected the wiring for both motors there and easily changed it from parallel to serial. WOW - finally, the 84 oz motors are running at their full potential. WOW - what a freakin difference. I can now plow through oak with ease. Hitting rock hard knots on pine is no longer an issue. I am now 3D carving pine, maple, and even red oak skipping the 1/4" end mill rough cut, and just directly carve with the 1/8 ball nose bit (at 45 degree angle) into maple at over 4000 mm/sec with no problem. But, just to be more sane, i try not to run it over 2500 mm/sec. I tried 3D carving in solid bamboo and skipping the rough cut, and it was cutting it very clean running at 4000+ mm/sec, but then the bit broke, so I think i was pushing it a bit too much. Now the issue is not the lack of power or solidity. I just have to learn the limitations of the bits and material. (I tried V carving in laminate flooring which has HDF backing, and that stuff is like milling steel. My carbide tip bits go dull before i can complete 1 piece. And, that was running them at only 900 mm/sec. I will try slower, but, i am thinking HDF may be too hard - not worth it).
As far as the main difference between parallel and serial - it makes sense. When the motors are in parallel the current is split between the 2 motors. For illustration purposes, say the motors are 2 amps at 4 volts on each coil. But, our drivers can only output 2 amps total. So, when it is wired in parallel the driver outputs 4 volts so that the current is 2 amps. But, those 2 amps are divided in parallel, 1 amp to each motor. Both motors see the 4 volts, but, each motor only gets 1/2 the current the driver is putting out.
In series, the driver is still set to output 2 amps, but now the load is higher resistance, so the drivers have to output more volts. Even though the driver is out putting double the volts, in series each motor only sees 1/2 the voltage, but, the full amperage passes through each motor. So, the full 2 amps now passes through each motor. The driver is now out putting 8 volts at 2 amps, and each motor only sees 4 volts each in series, but, at the full 2 amps. So, we just doubled the power to the motors, as you said, for Free. I haven’t turned my drivers down yet. I should, because they are still set to 1.1 volt, or the max of 2.2 amps. But, the motors are rated for it, it’s just the drivers are running on the hot side. I should be able to turn down to .8 with no major loss - but right now, i am very pleased with the added power. I noticed the X and Y run smoother.
I have added IR leds to my DW660, so I can make a Tach and view the RPM. Took off the hand tightner on the DW660 and printed a small holder for the IR leds, and painted a mark on the motor shaft just above the collet. I still yet have to program a separate arduino to view the RPM, but the IR sensors are out putting signals. The next mod is to read the RPMs and create a PWM controlled AC speed control to automatically control the RPM on the DW660 spindle. I got it designed, just need some spare time to build it.
You should post some pics of your mods…
sorry it took a few days - but, here are a few photos highlighting the dual pipes and the modified Zaxis-Gantry. Also the counter-weight system. Using a DW660 so far so good, if i were to do it over again, probably go for 1.5 HP or larger router. But, i am thinking once i get a decent tach synced pwm controlled ac speed control hooked up on it, it should work even better by maintaining rpm with or without load.
I put descriptions on image file names
That is pretty crazy.
I like the dual rails.
Does anyone have an accurate wiring diagram for series wiring for the mpcnc? Each time I wore them they either run in the same direction or not at all any help will be awesome thank you.
Accurate meaning?
I have a wiring harness for sale so you don’t have to worry about it, the picture a few posts up shows exactly how to modify a parallel cable, you should be able to translate that to any stepper color you have.
If you show a picture of you steppers I could give you a color chart.
It breaks down to two loops running from your control board through each coil then back to the control board. the coils are usually in order on the plugs. if you look at the hand drawing and substitute you plugs for the 12ab wiring it like that should work.
Interesting thread!
I was having stepper skipping problems on both X and Y, using our cheap little Wantai 42BYGHW811 steppers, which I had lying around from when we built a Cyclone. Just before I hit BUY on some stronger steppers, we came across this thread, so I tried out series connection.
I haven’t tried out actual milling yet in the new configuration, but just with a strength test, the results are really impressive. I’m using a calibration device that we built for helping with the initial commissioning of the MPCNC, which is held in place with elastic bands.
With steppers in parallel, the bands were stretched by 65mm, but in series, they were stretched by 186mm. Assuming the bands stretched fairly linearly (), we’re seeing a factor of three improvement! And – it feels like it too; before, you could shove the gantry out of position with a good push, but now you have to really lean into it, and the gantry crossbars are bending visibly before it skips. I started to measure actually how much force this was, but I’m struggling to measure it without dismantling the bathroom scales. It’s a lot.
Gotta finish the wiring, then we can test it out for real. More to come…
Awesome, I do feel it is the best option.
