Be sure to check out the Hall Switch endstops thread…
This is doable with the Jackpot board, it’s just not the default way.
For the Jackpot board, to make the end-stop switches active at all times (i.e not just during homing) you would need to edit the config.YAML file and enable hard-stops.
Note: there is another way (again on Jackpot board) to prevent unintended crashes that does not involve hard-stops, or adding extra limit switches, and it is to measure how much travel you want to allow, and input that in your max travel distance (in mm’s) for a given axis, and then enable soft stops on that same axis.
Tobi and I use a different board.
So, asking for a friend…
If you want to enable hard stops, couldn’t you also install both sets of Y switches in series as NC wiring?
(I also am using a non-Jackpot for my LR4(s))
Not sure about that other controller, but FluidNC supports multi endstops per input.
I could chain all the Endstops together as well. Makes troubleshooting harder though. ![]()
Steve, we love the boundaries you are pushing but this thread is from a user trying to get the stock machine up and running. The advice should be to build it as prescribed, on the yellow brick road.
