Price is right (<$230!?) on that 500 mm/s printer! I need to go back in time and order one! New baby LR3 is looking great! Your approach is the opposite of mine, I build first, worry about storage later. Your approach makes more sense and is why my garage is a hoarder’s paradise!
[Edit: Ordered. $219 shipped with coupon! Now to travel back in time…]
The "table"size is 27 by 42 inches. The available work space is roughly 10 by 24 inches after subtracting all the side plates and lost area due to the actual center of the tool not reaching the edge.
Many sub assemblies are done. Now I need to cut the YZ plates.
I bought some 12mm, black cast acrylic to use for the plates. After reading all the challenges with milling acrylic I was seriously considering just doing them in MDF. But the black Acrylic would look so nice.
After reading all the posts about techniques to cut it I decided to just jump in with the best ideas I could find: sharp tools, low RPM, slow feed, smaller DOC, Spray IPA, and be patient.
Here is a picture of the part after all the holes.
I cut the three holes where you see the deck screws first and then installed them to really hold it down. The rest of the holes were done in a single program.
I’m now going to do the three large cut-outs and it that goes well, the outline. These longer cuts I’m going to take as 3mm total DOC with holding tabs on the last pass.
A word of warning to future Acrylic workers: The edges are brutally sharp
I might wait a day to make the other one to let my hands heal a bit. (one cut while installing the 1/8 inch mill and another while cutting the holding tabs off).
The black sure looks good! One word of caution. If that truly is acrylic then be careful with the IPA. It will cause splinter cracks. I’ve had it happen to me and seen others with the same issue. If it’s polycarbonate then I think you are good with the IPA
I have drilled the holes for the linear rails and trying to tap them. I can’t seem to get them to tap cleanly.
I go slow and frequently clear the chips but the hole comes out over sized. I am using a matched set of drill and tap and have not had a problem using them on other materials.
@Jonathjon what did you do for mounting the linear rail? Did you use threaded screws or self-taping? I’m worried that if I use self-taping they might crack the plastic.
I used the wood screws Ryan sends in the kit but I did have to drill the hole a little larger. I tried it without doing that on the first one and it didn’t work out. But that ended up creating a large burr on the surface that caused me problems until I found it. I can’t remember what I ended up going up to.
In the second set I programmed the cut in Estlcam and used the 1/8” to drill. That was a mistake. It was too large of a hole. Went back and forth with that. Anythjnf large enough to grab in the hole was too large for the rail. I ended up cutting a small piece of filament and sticking it in the hole and that gave enough to grab securely.
My suggestion would be to take some of your scrap and see what size hole works good for your screws. You’ll be able to see if it makes any burs or if they don’t grab enough. And if you crack it that won’t matter in the scrap lol.
Huh. Never thought about trying heat sets in acrylic. I love using them in 3D prints. So much easier than captured nuts!! Might have to give that a try in some scrap and see if it works
I didn’t use the threaded inserts, but decided to try again with the 3mm tap. I ended up using a slightly larger drill, 2.87 vs 2.77mm. that allowed a easier tap run into the plastic without getting it too hot. The drill was actually a fractional inch not mm, but I don’t remember the size. after I get back into the shop I see what it actually is.
I’ll get the last 6 holes drilled and tapped then do a partial assembly to verify that my limit switch cables are long enough.
Limit switch wiring, the bane of our (my) existence. But it’s done. I had the longer wires on the right, but they weren’t long enough. I moved them to the left and made new switches for the right. The hardware part of the gantry is done. Motor sounds have been made
The Jackpot box just finished printing and after I mount it I can finish the wiring.
