On upgrade path: LR2 -> LR3, Clarksburg, WV, USA
I’ve never used Vectric Aspire. This web page lists info on how to edit a post processor for their system:
According to that doc, you would want to add code to the “HEADER” inside the “Block definitions” section. In the PP file you attached, the header starts on line #61. In the post processor, each GCode line has to be wrapped in double quotation marks, so G90 has to be entered as “G90”
In that scenario, the code in my script that reads as:
G92 X0 Y0 ; Set Current position to 0 on the X and Y axes.
G92 Z130 ; Set new Z position since probe to touchplate fails in negative numbers
G0 F3000 X150 Y150 ; move to +150,+150 inward from 0,0, prep for touch off
M0 Attach probe ; Pause to connect touchplate
G38.2 Z0 F900; Probe down to touchplate
G92 Z0.34 ; Set new Z position to thickness of touchplate
G1 Z40 F3000 ; Lift off touchplate
M0 Remove probe ; Pause and wait for touchplate removal
;M106 ; This will turn on an IOT relay to start a router or vacuum
Would have to be edited to instead say:
"G92 X0 Y0 ; Set Current position to 0 on the X and Y axes."
"G92 Z130 ; Set new Z position since probe to touchplate fails in negative numbers"
"G0 F3000 X150 Y150 ; move to +150,+150 inward from 0,0, prep for touch off"
"M0 Attach probe ; Pause to connect touchplate"
"G38.2 Z0 F900; Probe down to touchplate"
"G92 Z0.34 ; Set new Z position to thickness of touchplate"
"G1 Z40 F3000 ; Lift off touchplate"
"M0 Remove probe ; Pause and wait for touchplate removal"
";M106 ; This will turn on an IOT relay to start a router or vacuum"
Also, it’s probably a good idea to lookup what each command already in there, is doing. Here’s the pertinent existing code in the header of your Post Processor:
begin HEADER
"; [TP_FILENAME]"
"; Safe Z height: [SAFEZ]"
"; Tools: [TOOLS_USED]"
"; Notes: [FILE_NOTES]"
"; Generated [DATE] [TIME]"
"G90"
"M84 S0"
"M03 [S]"
"G21"
"G00 X0.000 Y0.000 Z0.000"
"G1 [SAFEZ]"
"G1 [XH] [YH] [F]"
"; Tool [T]: [TOOLNAME]"
"; Path: [TOOLPATH_NAME] [PATHNAME]"
"; [TOOLPATH_NOTES]"
In G-Code, a semicolon ( ; ) starts a “comment” which is ignored by the machine.
So, in the above code in your PP, any line that starts with a semicolon ( ; ) right after the double quote mark, is an ignored line that does nothing.
You can add a semicolon at the end of a line and add a comment explaining what the code does. When you look up (Google) each command that’s active in your header, you could add comments so you will always know more easily what that line does.
NOTE: Don’t delete the commented out inactive lines, because they are usually intended to make a comment appear in the rendered G-Code result, to provide helpful info for human eyes.
Nevertheless, when I filter your Header to focus on active lines that are not “commented” out, this is what is left — and I looked up what the function is for the first couple of lines, and added a comment for it:
"G90; specifies absolute positioning, as opposed to relative positioning"
"M84 S0; Disable steppers; S=Inactivity Timeout. If none specified, disable now"
"M03 [S]; Spindle CW / Laser On; [S] seems to be a variable/constant standing in for, most likely, speed"
"G21; specifies metric as opposed to imperial. all moves starting now have their units specified in millimeters (metric units)"
"G00 X0.000 Y0.000 Z0.000; command for rapid movement - seems to be going to 0,0,0"
"G1 [SAFEZ]"
"G1 [XH] [YH] [F]"
Etc.
The crucial part here is figuring where in that header to insert the new code. I’d “guess” that right after that G00. Someone here on the forum who knows more than I could help more.
thx for all the info ill look in to it
ill keep you posted if it works
doug thx it works like a charm
thx alot
Cool. Glad to help!
FAQ:
The Noctua fans that I used run on 12 Volts. However, the method I used can work with fans made for either 24V or 12V. I connected them straight to a spare 12V /24V “power out” port on the SKR board, so that every time the LowRider gets switched on, the fans come on. They don’t do temp monitoring for going on and off. They stay on whenever the LR3 is on. It was simpler for me to do it that. Please see the two port options highlighted on this schematic:
Based on this same question having been asked a few times, I just now edited the first Printables case listing (the one I first remixed for my build) to add a “FAQ” with this answer!
:slight_smile:
I just looked at mine (my SKR), and for reasons I cannot now remember (or perhaps no valid reason at all), I had small wires connected from the power-in port (highlighted lower one on the diagram above) to the motor power-out port (highlighted upper one on the diagram above), kinda like “jumpers” — again, I don’t know why. Maybe that was the only way to get power over there, or maybe I just mistakenly thought that. ???
Yes, those motor power terminals need to be tied to either the power in terminals with jumpers or directly to a DC power supply (if one is being used).
hi doug
2 years ago you help me with this an it work like a charm all this years
but was thinking can it go to z 0 when it finish a job coz i have to manually go to z0 every time
i want to start cutting another job
You can set that in your end gcode after each job to return to Z0 if that’s what you are wanting it to do.
yes but just Z
how can i modify it on my Post Processor
You can make it do that. But if you manually start/stop your router/spindle I would advise against it.
I am guessing you run the same job / material all the time? Unless you are 100% sure everything is the same thickness you usually want to reset Z0 each time.
Another thing you can do is have your start gcode only zero X and Y. That will leave Z set to what it was from the previous job. You will just have to manually set it any time you restart the machine.
Are you using Estlcam or something else?
im using vectric aspire
I have never used that one so I am not sure how you would adjust it. There should be a way to change it though.
Hopefully someone that has experience with that software will be able to chime in.
yes i was cutting 123 japaness tables ans had to do that all the time
