While tightening one of the m5 bearing bolts in place, I managed to crack my core casting (boo!). It also seems that the PLA is deforming around the bolt substantially as I drive it, risking stripping entirely. As I get ready to print a new one, does anyone have any advice? These seem really tough and hard to drive, should I prep them by running them on a couple of times to loosen them up? I never use them myself, but will use two nuts jammed together, so lack experience. Your advice is appreciated.
Sometimes they are pretty stiff. Yeah, you can run a bolt through them before putting them on the machine and that does work well.
I haven’t cracked any of my parts or deformed anything. Usually that happens if you tighten them too much, not as you are trying to tighten.
Everyone’s printer is a little different. It might help if you post pictures of the 3d printed parts. Maybe there is room for improvement on your print settings to make them stronger.
Well, this has to be the dumbest mistake ever. For some reason I have M8x1 bolts, but locknuts that are 1.25mm thread, not 1mm. Clicked the wrong thing when I ordered them I guess. Sorry all.
Look at this page Under Legs and feet. There is a note to run a bolt through ALL of the locknut prior to assemble. I haven’t seen a similar note in the LR docs. @vicious1
Then the nuts are not so tight that you can’t feel when the plastic is resisting.
Mike
I thought the instructions said to run the bolt into the nylocks first to soften them up, but it’s been a while since I read them.
Also, keep in mind nylock nuts can and do loosen up occasionally. I do a preflight check of all hardware before running each job.
Note if you’re going to prep all the nuts this way do NOT use a drill or electric screwdriver. The heat generated from the friction can melt the plastic insert.
Guess how I know
