NoVA Lowrider Build
Running into some trouble! Finally got around the adding end stops. I wired everything up, flashed the dual endstop firmware, and confirmed in repetier host that the end stops are functioning correctly. The issue is that homing Y does not work correctly, as soon as the Y1 switch is triggered the machine freezes, and Y2 does not continue to home. Swapping the end switches plugs on the board lets it home but I hear one of the steppers skipping. Thoughts?
I’ll also add that I’ve successfully used my LR in some projects. I finished the jointer:
and even made some money:
