It seems some endmill makers use ‘guy inches’ when they make their tools. I have a brand new endmill, carbide coated, blessed by the pope on high and next in line for the throne in england… that I’ve been saving for a while. Just because what I had was good enough, but I had a couple good projects in the works and decided to switch over. Only to see it drop out part way through a cut. Fortunately I was there, heard the pitch change and shut things down before it did too much damage, so I salvaged the project.
Investigating the issue, once the collet got hot, out she came. I had to heat things up and then really crank things down to keep the bit working. I thought my collet was shot, got a new one, same issue. So I swapped back to a different bit, no issue.
So out with the calipers, and sure enough it’s .23" Good enough for a drill style chuck, but not a collet. And also explains the extra bit of hand work I’ve had to do in order to get parts to fit.
I’ve had this on my shelf for months, don’t remember where I got it. So it’s in my junk pile, lesson learned. Calipers on every new bit before it enters rotation.
