No movement at all
21:00:09.886 : OpenGL version:4.5.0 - Build 22.20.16.4836
21:00:09.886 : OpenGL extensions:GL_3DFX_texture_compression_FXT1 GL_AMD_depth_clamp_separate GL_AMD_vertex_shader_layer GL_AMD_vertex_shader_viewport_index GL_ARB_ES2_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_cl_event GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_compute_shader GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_fragment_shader_interlock GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_post_depth_coverage GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_robustness_isolation GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_separate_stencil GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_polygon_offset_clamp GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_framebuffer_fetch GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_compression_s3tc GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_IBM_texture_mirrored_repeat GL_INTEL_conservative_rasterization GL_INTEL_fragment_shader_ordering GL_INTEL_framebuffer_CMAA GL_INTEL_map_texture GL_INTEL_multi_rate_fragment_shader GL_INTEL_performance_query GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_KHR_context_flush_control GL_KHR_debug GL_KHR_texture_compression_astc_hdr GL_KHR_texture_compression_astc_ldr GL_NV_blend_square GL_NV_conditional_render GL_NV_primitive_restart GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
21:00:09.886 : OpenGL renderer:IntelĀ® HD Graphics 500
21:00:09.886 : Using fast VBOs for rendering is possible
21:00:35.705 : No start signal detected - forcing start
21:00:35.785 : N1 M11034
21:00:35.785 : N2 M115
36
21:00:35.785 : N3 M10536
21:00:35.785 : N4 M114
35
21:00:35.785 : N5 M111 S698
21:00:39.895 : No start signal detected - forcing start
21:00:39.905 : N1 M110
34
21:00:39.905 : N2 M11536
21:00:39.905 : N3 M105
36
21:00:39.905 : N4 M11435
21:00:39.915 : N5 M111 S6
98
21:00:39.915 : N6 T060
21:00:39.915 : N7 M20
22
21:00:39.915 : N8 M8019
21:00:39.915 : N9 M105
46
21:00:40.095 : N10 M220 S10080
21:00:40.095 : FIRMWARE_NAME:Marlin bugfix-2.0.x (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1 E CNC EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
21:00:40.095 : Cap:SERIAL_XON_XOFF:0
21:00:40.095 : Cap:BINARY_FILE_TRANSFER:0
21:00:40.095 : Cap:EEPROM:1
21:00:40.095 : Cap:VOLUMETRIC:1
21:00:40.095 : Cap:AUTOREPORT_TEMP:1
21:00:40.095 : Cap:PROGRESS:0
21:00:40.095 : Cap:PRINT_JOB:1
21:00:40.095 : Cap:AUTOLEVEL:0
21:00:40.095 : Cap:Z_PROBE:0
21:00:40.095 : Cap:LEVELING_DATA:0
21:00:40.095 : Cap:BUILD_PERCENT:0
21:00:40.095 : Cap:SOFTWARE_POWER:0
21:00:40.095 : Cap:TOGGLE_LIGHTS:0
21:00:40.095 : Cap:CASE_LIGHT_BRIGHTNESS:0
21:00:40.095 : Cap:EMERGENCY_PARSER:0
21:00:40.095 : Cap:PROMPT_SUPPORT:0
21:00:40.095 : Cap:AUTOREPORT_SD_STATUS:0
21:00:40.095 : Cap:THERMAL_PROTECTION:1
21:00:40.095 : Cap:MOTION_MODES:1
21:00:40.095 : Cap:CHAMBER_TEMPERATURE:0
21:00:40.095 : N11 M221 S100
80
21:00:40.155 : N12 M111 S684
21:00:40.155 : X:0.00 Y:2000.00 Z:0.00 E:0.00 Count X:0 Y:400000 Z:0
21:00:40.155 : echo:DEBUG:INFO,ERRORS
21:00:40.155 : Begin file list
21:00:40.155 : N13 T0
8
21:00:40.155 : N14 M155 S1*85
21:00:40.165 : End file list
21:00:40.165 : echo:Unknown command: ā€œM80ā€
21:00:40.185 : echo:DEBUG:INFO,ERRORS
Here’s M122
21:07:04.128 : N18 M122*27
21:07:04.128 : X Y Y2 Z Z2
21:07:04.128 : Enabled false false false false false
21:07:04.128 : Set current 800 800 800 800 800
21:07:04.128 : RMS current 792 792 792 792 792
21:07:04.128 : MAX current 1117 1117 1117 1117 1117
21:07:04.128 : Run current 15/31 15/31 15/31 15/31 15/31
21:07:04.128 : Hold current 7/31 7/31 7/31 7/31 7/31
21:07:04.128 : Global scaler 133/256 133/256 133/256 133/256 133/256
21:07:04.128 : CS actual 0/31 0/31 0/31 0/31 0/31
21:07:04.128 : PWM scale 0 0 0 0 0
21:07:04.128 : vsense
21:07:04.128 : stealthChop false false false false false
21:07:04.128 : msteps 256 256 256 256 256
21:07:04.128 : tstep 0 0 0 0 0
21:07:04.128 : pwm
21:07:04.128 : threshold 79 79 79 658 658
21:07:04.128 : [mm/s] 800.63 800.63 800.63 24.03 24.03
21:07:04.128 : OT prewarn false false false false false
21:07:04.128 : OT prewarn has
21:07:04.128 : been triggered false false false false false
21:07:04.138 : off time 0 0 0 0 0
21:07:04.138 : blank time 16 16 16 16 16
21:07:04.138 : hysteresis
21:07:04.138 : -end -3 -3 -3 -3 -3
21:07:04.138 : -start 1 1 1 1 1
21:07:04.138 : Stallguard thrs 0 0 0 0 0
21:07:04.138 : DRVSTATUS X Y Y2 Z Z2
21:07:04.138 : stallguard
21:07:04.138 : sg_result 0 0 0 0 0
21:07:04.138 : fsactive
21:07:04.138 : stst
21:07:04.138 : olb
21:07:04.138 : ola
21:07:04.138 : s2gb
21:07:04.138 : s2ga
21:07:04.138 : otpw
21:07:04.138 : ot
21:07:04.138 : Driver registers:
21:07:04.148 : X 0x00:00:00:00 Bad response!
21:07:04.148 : Y 0x00:00:00:00 Bad response!
21:07:04.148 : Y2 0x00:00:00:00 Bad response!
21:07:04.148 : Z 0x00:00:00:00 Bad response!
21:07:04.148 : Z2 0x00:00:00:00 Bad response!
21:07:04.148 : Testing X connection… Error: All LOW
21:07:04.148 : Testing Y connection… Error: All LOW
21:07:04.148 : Testing Y2 connection… Error: All LOW
21:07:04.148 : Testing Z connection… Error: All LOW
21:07:04.148 : Testing Z2 connection… Error: All LOW
The good news is, you’re connected via repetier. But this means you’re not communicating with any of the drivers.
So I’m guessing either bad drivers or I’m either missing jumpers somewhere, or how the wrong placement of said jumpers.
Now im certain it has to do with the jumpers under the drivers!
21:54:35.759 : Driver registers:
21:54:35.759 : X 0xFF:FF:FF:FF Bad response!
21:54:35.759 : Y 0xFF:FF:FF:FF Bad response!
21:54:35.759 : Y2 0xFF:FF:FF:FF Bad response!
21:54:35.759 : Z 0xFF:FF:FF:FF Bad response!
21:54:35.759 : Z2 0xFF:FF:FF:FF Bad response!
21:54:35.769 : Testing X connection… Error: All HIGH
21:54:35.769 : Testing Y connection… Error: All HIGH
21:54:35.769 : Testing Y2 connection… Error: All HIGH
21:54:35.769 : Testing Z connection… Error: All HIGH
21:54:35.769 : Testing Z2 connection… Error: All HIGH
This may or may not be analogous, but I will share my experience anyway. In my Rambo 1.4 board I had the end stops wired wrong. It didn’t even look like anything turned on.
On my skr1.3 (not for mpcnc, but ender ) the drivers wouldn’t respond in prontoface until I switched the jumper to external power and provided a source more powerful than the USB.
I’ll give that a go, Ben. Thank you.
Ok. I looked at the manual. TMC5160s are spi, right? So remove those red jumpers outside the drivers. I can see them in the pic you posted. Under the drivers, they should look just like the one you removed in your pic.
Giving that a go now. However, I am unable to connect back to the machine now.
22:55:30.735 : T:170.00 /0.00 @:0
22:55:31.770 : T:170.00 /0.00 @:0
22:55:32.770 : T:170.00 /0.00 @:0
22:55:33.770 : T:170.00 /0.00 @:0
22:55:34.766 : T:170.00 /0.00 @:0
22:55:35.762 : T:170.00 /0.00 @:0
22:55:36.777 : T:170.00 /0.00 @:0
22:55:37.769 : T:170.00 /0.00 @:0
22:55:38.769 : T:170.00 /0.00 @:0
22:55:39.769 : T:170.00 /0.00 @:0
22:55:40.772 : T:170.00 /0.00 @:0
22:55:41.767 : T:170.00 /0.00 @:0
22:55:42.775 : T:170.00 /0.00 @:0
22:55:43.775 : T:170.00 /0.00 @:0
22:55:44.766 : T:170.00 /0.00 @:0
22:55:45.770 : T:170.00 /0.00 @:0
22:55:46.771 : T:170.00 /0.00 @:0
22:55:47.769 : T:170.00 /0.00 @:0
22:55:48.766 : T:170.00 /0.00 @:0
22:55:49.776 : T:170.00 /0.00 @:0
22:55:50.767 : T:170.00 /0.00 @:0
22:55:51.770 : T:170.00 /0.00 @:0
22:55:52.773 : T:170.00 /0.00 @:0
22:55:53.770 : T:170.00 /0.00 @:0
This is all I am getting now. I have a feeling that my resistor may not be high enough. I only have a 220Ohm in there. Think that could be an issue?
22:58:22.708 : N15 M122*22
22:58:22.708 : X Y Y2 Z Z2
22:58:22.708 : Enabled false false false false false
22:58:22.708 : Set current 800 800 800 800 800
22:58:22.708 : RMS current 792 792 792 792 792
22:58:22.708 : MAX current 1117 1117 1117 1117 1117
22:58:22.708 : Run current 15/31 15/31 15/31 15/31 15/31
22:58:22.708 : Hold current 7/31 7/31 7/31 7/31 7/31
22:58:22.708 : Global scaler 133/256 133/256 133/256 133/256 133/256
22:58:22.708 : CS actual 0/31 0/31 0/31 0/31 0/31
22:58:22.708 : PWM scale 0 0 0 0 0
22:58:22.708 : vsense
22:58:22.708 : stealthChop false false false false false
22:58:22.708 : msteps 256 256 256 256 256
22:58:22.708 : tstep 0 0 0 0 0
22:58:22.708 : pwm
22:58:22.708 : threshold 79 79 79 658 658
22:58:22.718 : [mm/s] 800.63 800.63 800.63 24.03 24.03
22:58:22.718 : OT prewarn false false false false false
22:58:22.718 : OT prewarn has
22:58:22.718 : been triggered false false false false false
22:58:22.718 : off time 0 0 0 0 0
22:58:22.718 : blank time 16 16 16 16 16
22:58:22.718 : hysteresis
22:58:22.718 : -end -3 -3 -3 -3 -3
22:58:22.718 : -start 1 1 1 1 1
22:58:22.718 : Stallguard thrs 0 0 0 0 0
22:58:22.718 : DRVSTATUS X Y Y2 Z Z2
22:58:22.718 : stallguard
22:58:22.718 : sg_result 0 0 0 0 0
22:58:22.718 : fsactive
22:58:22.718 : stst
22:58:22.718 : olb
22:58:22.718 : ola
22:58:22.718 : s2gb
22:58:22.718 : s2ga
22:58:22.718 : otpw
22:58:22.718 : ot
22:58:22.728 : Driver registers:
22:58:22.728 : X 0x00:00:00:00 Bad response!
22:58:22.728 : Y 0x00:00:00:00 Bad response!
22:58:22.728 : Y2 0x00:00:00:00 Bad response!
22:58:22.728 : Z 0x00:00:00:00 Bad response!
22:58:22.728 : Z2 0x00:00:00:00 Bad response!
22:58:22.728 : Testing X connection… Error: All LOW
22:58:22.728 : Testing Y connection… Error: All LOW
22:58:22.728 : Testing Y2 connection… Error: All LOW
22:58:22.728 : Testing Z connection… Error: All LOW
22:58:22.728 : Testing Z2 connection… Error: All LOW
22:58:22.728 : ok
Whats with the Ok at the last promt?
The ok is just saying it heard your M122.
The 170 is normal. You don’t need a resistor, it is set to 170C in software. You are still not talking to your drivers.
I keep receiving a kill operation on display.
Think perhaps I fried the drivers?
What firmware are you using? Did you compile it yourself?
I used… The one that was posted on here that was already compiled. I apologize, but I can not remember the user that posted it.
Was it configured for 5160 drivers?
I believe so, let me find the link.
https://forum.v1e.com/t/teaching-tech-skr-1-3/11897/2
Autobot blocked my post for the link to this forum. ha ha Here
