Hey everyone. I just wanted to say hi and show off my completed build. It has a 36" x 36" x 3" cut space. A friend printed all the components in PLA. The MPCNC is mounted on a table with leveling feet and two sheets of 3/4" MDF on top. I am using a RAMPS 1.4 to drive it and a Makita router for the spindle.
One of the first things I cut with the MPCNC was brackets for the assembly that holds the keyboard, mouse, and monitor. I used left over EMT for the vertical pole. There is a 6" diameter circle of 12ga steel welded to the top of the EMT tube. The pole swivels in the lower brackets and the monitor/keyboard mount swivels on the top.
The power supply (an old ATX power supply) is mounted under the table and the RAMPS is mounted below it in a 3d printed box with two 40mm fans.
When looking at the photo of the side… The 4 outlets on the left are always on and power the computer and monitor. The 4 on the right are switched by the emergency stop switch (bottom left of photo). A single cord runs from those junction boxes to the wall for a nice clean setup.
Make sure that cord is really really loose. We work with very tiny tolerances and pulling on that is multiplied in force and has caused many many an issue.
That makes sense. I will keep that in mind. The spring that is attaching the cord to the chain is the softest/floppiest spring I could find. It takes next to no force to stretch it and it only really stretches at the far front/left corner of the table.
Not sure if any of you are still active. But I am just starting to plan my CNC build. Im in the detroit area (Trenton / Grosse Ile). Would love to talk to a local DIYr. I also do 3D printing, and I have an xTool P2. But this LR4 build has me drooling.
