If you do, please let us know how it goes.
awesome thank you sir. Now to see if i can edit my order
I sure will
Hey, just for clarity, I was thinking that you would epoxy the 2 halves together for strength and also thinking that it would only be temporary so that you could get some new plates milled. Regarding whatever glue you do use, I would recommend avoiding the areas around the edges of the holes and cutouts.
PS: of course if you do get liberal with the epoxy, and some squeeze out ends up oozing into the cutout openings or the screw hole openings, you could always wipe (while wet) or grind the squeeze out off after it’s dry and redrill the holes, though be careful about what drill bit size you choose if you do that, as if you open the holes up too much then the screws won’t have anything to bite into.
How did this print go?
I ended up irdering the plates from V1E
So i do not see many using sketchup. Just checked it out, are you just using browser free edition?
Yes. I used the pro version for many years, and then last year or two I backed off to just using the free version, but I happen to have held onto 2017 edition of the free version, and it was the last year edition that you could install the free version directly on your computer. That’s why I’m using it. I found some free plug-ins to spruce it up and make it able to do what I need it to do.
@DougJoseph Given recent discussions about YZ Plates and the fact that I intend to go this route, I made updated versions of the Split YZ plates based on the newer v1 dxf and published the files on Printables.
I tried to maintain the split in roughly the same spot as you and, of course, gave attribution and links back to you and your idea.
Cool! Thanks! Great job.
Cool! Glad to hear it!
